Discuss BG Dual RCD metal DB's in the UK Electrical Forum area at ElectriciansForums.net
Deleted member 9648
Anyone had issues with the RCD's? Added a spur from a new DB yesterday (not installed by me). The RCD failed the 5x test when tested at the load terminals with all mcb's off. Perplexed I tried the other RCD with the same result. MFT tested the RCD on another job later with results as expected.
Have you tried it with the RCD Load Neutral Terminal disconnected as well as the MCB'S switched off?
Yes, I have had 2 BG RCDs faulty out of the box. Gave BG a good shot but had quality issues every single time I have used them. Utter garbage.
No I didn't test with the load N disconnected as it's not something I've ever had to do before with other boards...Will try that though.I've got to go back to investigate as clearly I cant do a MW for the spur I installed with the failed 5x test. PITA for a tuppence halfpenny job.
Reply to BG Dual RCD metal DB's in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone, I wondered if anyone could help me with something that has been niggling me please?! When a Solar PV feed in circuit is installed...
Hi Guys, Long time member and not a regular user here. I do pop in here when the odd unknown pop's up and unable to locate an electrical dilemma...
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
Hello all I have recently installed a sub main in 4mm 3-core SWA, approx length 45 metres, to feed a small garden office. Final circuits in the...
