Discuss blackest panels in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Have you found a panel blacker than the penlight delta black?
How black are the sun power signature blacks? does anyone have a photo of them? or even a data sheet? I can't seem to find the data sheet for them anywhere just for the normal 327W panel.
Are there any other completely black panels?
If you're not limited on roof area/space then you should look at the Solar Frontier CIS panels - extremely dark, sleek and all one tone as no busbars/individual cells etc. Higher yield per kWp than crystalline Si too.
Yes well it's only a 12 panel system so 260 is good, I've looked at datasheet and price but datasheet doesn't always represent what they actually look like in the flesh! May ask Rexell for a photo
Reply to blackest panels in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Heeelp! I have an 11kW/21A motor which is attached to a hydraulic power pack. I have replaced the old panels with new, using the same star delta...
I am a retired Electrician and started looking at Solar Power, (Black Magic to me), after much reading of "How To", I decided to build myself a...
Hi all, total newbie to the forum. I sincerely hope that those in the know-how would be able to assist me. On my semi-detached house we have an...
Hi, I would love some help understanding an issue I’m having on a 16mm SWA cable running from the CU in my house to the CU in the shed. I believe...
