Discuss Blanking off existing switches in the The Welcome Forum area at ElectriciansForums.net
just get a plasterer in. he'll soon bury them. :ciappa:
I need to leave 2 3 gang switches in place in case of a change of use in the future and don't really want people to flick the switches as I've installed a new PIR controlled contactor and would sooner leave them in behind a plate if I could.
well then , if it's a grid, fetch a plumber. they's used to firking around in grids. @ OP. why not remove switches, wago the cables in the configuration you want. fit a blank plate, then switches can easily be re-fitted in the future if required. sssimpless.
Link them in a Wago behind the grid with a note on the cables and blank the switch and the D/B, sorted.
These people are a bit strange that was what I was going to do but they want to see the switches in :)I'm just going to link them and tell them it wouldn't work. I had to break into the live feed and couldn't break into the switch lines due to layout so if people start flicking switches it's potentially a very poor lighting arrangement :s
Reply to Blanking off existing switches in the The Welcome Forum area at ElectriciansForums.net
Hi, I'd like to move the existing socket that feeds the boiler down to where I've pencilled in that can be seen on the photo. The socket to the...
Hi, I am looking to convert a 2 way light into just control by single switch. I have searched and looked for similar questions here, and found a...
as title, am looking for square edge grid switches. I rewired a little bungalow and wired it for grid switches beside double sockets in kitchen...
Hi all, DIY'er here looking for a bit of advice so please go easy on me. In my dining room there is an existing single pendant and i would like...
I am swapping a light switch in France for a motion sensor with two simple connections. The switch I wish to remove has two black into one...
