Discuss Blue commando socket in the UK Electrical Forum area at ElectriciansForums.net
Hellmooth
Hi I have a commando socket to fit in my work unit to supply a gas welder, am I right in saying these come in 16 and 32 amps? What size of breaker would be best, I can't seem to find the right info on the welder for working out the max load?
thanks
craig
Commando sockets come in many sizes some over 100A but 16 and 32A are common sizes for small commercial applications. Blue usually denotes it's 3-pin suitable for single phase.
You need to find out the load for the welder first and work from there
Yeah blue is for 230v I believe.............I've asked the welder he doesn't have a clue he just uses it :) the info on the welder ranges from 120a to 200 odd, which clearly isn't correct! I tried it on a 16a type c which was spare on the board, kept tripping so tried it on a 32a and it worked fine, want to make sure first tho before I put it on its own breaker.
So at first you don't succeed....
Not the best approach is it?
I f you get it working temp then you will be able to work out the start up current as well mate, then just look at your MCB curves and work it out from there. Like iamelectric said, with a D type you need to be careful with your Zs values as these are 1/4 the maximum values of a B type and 1/2 of a C type. Plus if you are testing the circuit cold i would check out the permissable values in the back of your GN3 for such a piece of equipment.
Reply to Blue commando socket in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Just a quick one regarding the need for RCD protection for socket outlets rated up to and including 32A. I have been tasked to install...
Evening, I’ve just put an offer on a house without thinking too much of the electrics. It currently has 2 electric showers and an electric oven...
Hi guys, Rewired a unit where they make dentures, builder today has asked to install 16a commando socket with isolator (no problem) however...
I have an old Migatronic Automig X 200 welder configured as 380V 3-phase unit. Migatronic for spec. I have a 220V 3-phase point in my garage...
