Discuss Bmw Speed sensor pulse wire in the Auto Electrician Forum area at ElectriciansForums.net
Dm100
As above, I purchased a front parking sensor kit for my BMW f20 118d 2012. The system requires connection to a speed pulse wire to activate the sensors below a certain speed. Does anyone know what colour wire it is and where is the best place to tap in to it?
Reply to Bmw Speed sensor pulse wire in the Auto Electrician Forum area at ElectriciansForums.net
Hello there, I’m in the process of mapping out a relatively standard S-plan system for my parents central heating and hot water system. Not sure...
Hello, I have installed 6 recessed lights in my living room as well as wall boxes. I’m now at a point where to need to run the wiring. I plan to...
Hello, I am hoping this is in the correct forum. To start, I acquired a film processing machine that runs on 3 phase. Now before getting the...
Hello everyone, I hope you are doing well. Several years ago I purchased an older 1971 home (aluminum wiring that has since been fixed with al/cu...
Looking for some cabling advice for my garden project. I’ve put together this diagram below, which hopefully explains what I’m trying to achieve...
