Discuss Boiler in bathroom EICR code in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
jibjob
Hi Guys,
Came across this today in what seems like a newly refurbished bathroom. As you can see from the picture (hopefully) is that the boiler is less than 600mm from the edge of the shower enclosure. Not sure what the IP rating of the boiler is but the adjacent switched connection unit & wireless receiver aren't likely to be IPX4. It's a large shower enclosure which incorporates a shower tray with a walk in/drying area meaning the shower head although not fixed is some distance from the boiler which is partially set back into a recess & quite high up. I'm unsure on how to code it assuming it needs coding at all although I'm leaning towards giving it a C3 obviously with an explanation as to why & what could be done to rectify it.
The boiler circuit is RCD protected & all main bonding is in place.
Any thoughts would be most welcome
Reply to Boiler in bathroom EICR code in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Morning all So the site I'm based at recently had some work done (think partitioners). This package of work included electrical. This was...
8K
Hi all, I am looking for some advice regarding old rewireable (3036) fuse boards in regards to additions and alterations. I am an electrician and...
4K
Hello, I'm after some coding advice / opinions regarding EICR of warehouses / offices. In others opinion would this be agreeable (helplines closed...
Hi all Eicr being undertaken, what code if any would you consider for this scinario Small bathroom in a flat, with airing cupboard inside, no...
I've taken the mirror off my parents' bathroom wall as they've asked me to paint it (full disclaimer on quality issued to them!). It's one of the...
