Discuss Boiler or stand alone radiators in the Central Heating Systems area at ElectriciansForums.net
it0000
I am renovating a 2 bedroom flat that currently has no central heating and will rent out. Looking to the future I understand electric is best option but confused as to whether I should go with a combi boiler and hot water radiators or Rointe stand alone electric radiators? I cannot find an independent source of comparison. Hope you can help.
Gas still cheaper per kWh, but for how much longer depends on politics.
Electric heating is more reliable, more efficient, cleaner, more responsive, cheaper to install and generally better in all/most ways than water based systems other than running costs.
Historically gas has been 3-4 times cheaper than electric heating to run even allowing for the fact gas boilers are only circa 90% efficient and losses in pipework etc.
Reply to Boiler or stand alone radiators in the Central Heating Systems area at ElectriciansForums.net
At the moment it depends on the weather on how well the central heating works, the main problem is the Nest Gen 3 thermostat only measures the...
Hi everyone, my house has an air-to-heat system that generates hot water in a boiler. This boiler is then connected to the central heating...
Hello! I've just moved in to a new property with "all electric" heating system and trying to figure it out. The agency/landlord are of no help so...
Got a customer with a little dilemma. They have a rental cottage attached to their main house, and have successfully let it out for a few years...
Hi. We are looking at installing a Wiser smart heating system inc. trvs We are currently electric only, with normal rads and a Heatrae sadia...
