Discuss Boiler tripping main fuse in the Central Heating Systems area at ElectriciansForums.net
I have a grant vortex combi boiler and it has started tripping the main fuse when the programmer calls for heat.
Any ideas.
Regards
Faulty Pump or Valve, do you have a maint contract for your boiler? if yes contact the provider.
Is that an external oil boiler?
It's worth getting someone out to look at it either way as there are a number of things it could be. Trying to diagnose long distance is guesswork at best.
Not external, internal.
Going to disconnect the pump from the PCB and call for heat from the programmer tomorrow, if it doesn't trip that would suggest it is a fault with the pump ??
Regards
Problem solved, when we went to remove the pump the pump cable was jammed between the front of the flame box and flame box casing, when we took the front off the cable was fried. Put a new cable in and it's all working now. Thanks for all your help Regards
Glad you sorted it, nice one.
Reply to Boiler tripping main fuse in the Central Heating Systems area at ElectriciansForums.net
Anyone tell me where to connect the two wires that switch the boiler on via the programmer and the 2 wires that call for heat on the ufh control...
At the moment it depends on the weather on how well the central heating works, the main problem is the Nest Gen 3 thermostat only measures the...
I generally consider myself pretty up on heating systems but this has me slightly stumped… An otherwise very simple system boiler on what I...
Hi I'm in a bit of a pickle trying to set up my hot water and central heating systems. Got a gas boiler with a pressure tank and a motor...
So I’ve been having this issue with my boiler for a while now, I’ve currently got one stat in the hall that when I turn it on it brings the...
