Discuss bonding gas/water where not yet installed. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
J
jase31
Does an installation require bonding to Gas/Water where there is no gas or water installed?
The consumer unit is is bonded to MET by 16mm cable. However there is no gas/water bonding to the incoming gas stop tap, and water stop tap - there is no other pipework in the property beyond the stop taps.
Does bonding need to be installed to the stop taps, or as there is no water/gas pipework beyond the stoptap is it OK that there is no bonding.
Reply to bonding gas/water where not yet installed. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Not sure on this one. Mains water is coming up from the ground in lead pipe in bathroom. 2 inches of copper pipe before the stop tap. All...
Hi I have a 1st fix domestic install on the go and need to leave a socket for other trades to use after me. There is no main bonding at the...
Hi forum members, I hope someone can assist with my enquiry. I have been advised that to comply with BS7671 Reg 132.16 my solar and battery...
Hi, I'm having a new boiler fitted in a new location. I need to provide power for the boiler which I'm looking to do myself. Boiler: Ideal Logic...
Hi, went to have a look at a job today, customer has had gas supply company out (for another issue) and they have commented that the protective...
