Discuss Bosch PMF 180E in the Electrical Tools and Products area at ElectriciansForums.net
E
ezzzekiel
anybodys views,
bought one couple days back and first day fine, then trimmed some laminate flooring that had been laid a bit tight and both blades destroyed on a 20min job and at about £20 pop hardly worth the purchase.
prob better to stick with trusty circular had same blade in for years
I bought one on impulse for a re-wire I’m currently doing. I’ve used it for cutting floor boards (T&G), and access points in solid chipboard floors in the loft. Does a really nice job, neat cuts, and easy to use, thou a little noisy! You do have to watch your depths with respect to pipes & cables in notched joists, but apart from that, a nice piece of kit. Shame they only do a 230v version.
[QUOTE Shame they only do a 230v version.[/QUOTE]
They also do a 10.8Li-ion blue version Was going to buy one this month (c.£180 with case accessories etc) but have just discovered hydraulic hole punches and they're not cheap! but very shiny!!
I have one and the blades are lasting well... 3 rewires since getting it and the circular is now redundant.
Think you were unlucky mate...
Im thinking of getting the 10.8v one as i already have some of that kit. If they are any good they look really usefull. the 10.8v wouldnt last long i know but i would only need it for short runs.
anyone got one?
what do you think of it?
how are the blades holding up - maybe i was unlucky
They seem to be doing fine. I've cut quite a few floorboard & access points, and the blade seems to be still going strong. I think you need to make sure you have the right blade, as from the leaflet included, there are different blades for different thickness and types of wood.
I was looking at the 10.8 blue version, but wasnt sure how long the batteries would last when cutting boards etc?
I got one a couple of months back and can't believe how much I use it. Really useful bit of kit.
But, I have gone through quite a few blades....... made worse by not paying enough attention on whether I've got the right blade fitted (B&Q were doing a 3 for 2 offer which covered the blades).
Use the right blade and don't overheat it and you'll be fine
Bought one a while back (PMF180E) and the more I use it the more I find out how handy it is. I have not been tempted by the cordless version though, aside from drills I can't see the point as the batteries all go duff sooner or later.
I've got the fein same blades. I find the biggest problem as mention before is overheating of the blades and melting them. I have found stroking the cut without using much pressure extends the life of blades :)
I have had a Bosch PMF 180E for a couple of years and would not be without it.
You can get the blades on ebay a bit cheaper than when the tool first come out from a seller called: hendr01d
Cheers Chris.
Bought one last week for cutting holes in skirting and floor boards. Overheating can be a problem if you are over eager with pressure. Let the tool do the work, and I find wiggling the cutter helps with plunge cuts. I killed blades on T&G floor boards when slicing the tongues. Too much grit. I then used old blades to shift the dirt before using a new one to cut the wood.
Good news on the Fein blades fitting, and will check out the e-bay seller now.
Reply to Bosch PMF 180E in the Electrical Tools and Products area at ElectriciansForums.net
Ok, so this is for plastering, and it's been taken from our tiling forum, posted by a member named 'tiler burden' - so I'm not taking credit. But...
71K
