Discuss Box sinkers in the Electrical Tools and Products area at ElectriciansForums.net
I used to have the first Armeg box sinker with the big 'core' type drill bit and the square chisel.
Brilliant in thermal blocks, but other than that ,not very good to be honest.
I have now gone back to old faithful. The hammer and bolster/chisel.
The box sinker hasnt been out the case for a few years. In fact, im not entirely sure where it is.:D
Hey.
I had one of them ARMEG thingys too, waste of time, snap the pilot drill and its useless.
Like J said, blood, sweat, black mans pinches and a hammer and bolster, never fails (bosch multidrill is good too).:D
If I havent got the Hilti chaser and vac out, I have found the sds with this is great. (make sure your SDS has the chisel function)
Reply to Box sinkers in the Electrical Tools and Products area at ElectriciansForums.net
Wallbox Fuse Box Lite Single Phase has anyone used one of these? I've installed one feeding a Pulsar Max, the Pulsar Max is set to 32Amp max. The...
Has anyone come across automatic strippers to pull of the sheath of a cable already in a back box. The regular ones can do it to a degree but due...
Hi All. Anyone got experience/usage of using the Quickfix Junction Box, with the Wago 221 Connectors ? https://www.quickfixjb.co.uk/...
I have just checked a double outlet and it trips at 18ma. It was supposed to be faulty. Washing machine had a bad heater which got replaced but...
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
