Discuss Brass Style "Plastic" Light Switches in the UK Electrical Forum area at ElectriciansForums.net
SKY
Hi All
Are there plastic faced imitation brass light switches availible on the market?
So basically a plastic faced socket that looks like brass.
I'm sure I have seen a sort of lacquered plastic foil over switched to make them imitation brass.
A bit like a xmas tree ball ball.
There used to be a brass(ish) metal cover thats goes over a standard switch (not my style) but i dont know if you can still get hold of them?
Because its you Sky I'll have a google search for you.
Cheers Paul - I have also looked but no luck.
I'm sure they used to do them in screwfix made by LAP but I cannot see brass in their current book or on-line.
Im sure these are them
Volex 10AX Intermediate Sw Wht Ins BB Round Edge | NoLinkingToThis
got a customer who has no earth in lighting but want to keep brass style fittings.
Wonder if I can get screw covers for these!?
Do a google search for "brass looking switches" and take your pick, loads on there.
ps. Why are you looking for plastic brass looking switches? If you dont have an earth/cpc to the switch you can always use nylon lug screws. Just a thought?
you can't use brass or metal switches even with nylon screws or lugs when there s no cpc
Reply to Brass Style "Plastic" Light Switches in the UK Electrical Forum area at ElectriciansForums.net
Hi, looking at ranges from MK, and BG, tend to be square, or crabtree, Schneider, very rounded. What do you fit to make house reasonably up to...
Hi all I have a professional coffe machine working at 220 V and it currently drain about 2,5 kW of power. I have made this simple and horrible...
Hi there, I am looking for some advice re: putting new sockets and usb sockets in my home. Someone will be rewiring the entire house but I have...
Hi guys, I don’t really know where to post this, sorry if it’s in the wrong place. After posting a thread about old lead sheathed cable in my...
Not the usual per-1966 sort of "no CPC in wiring issue" but plastic light switches in plastic back-boxes in trunking wired in singles. The lights...
