Discuss Breaking the tails in the Australia area at ElectriciansForums.net
W
wattsup
So, I now am breaking the law. I cannot isolate without breaking the 'seal'
The tails are my property, yet they are protected by their 'do not remove seal' in effect they are not acting legally.
They the 'board' do not provide isolation, are they breaking the 'law' I would love to take them to court. And will do so one day.
For me it makes no sense, but some customers think ahhh bloody cowboy, interfering with the supply...as though you can change a dis. board or more in my line of work installing back up generators without 'tampering'
Try explaining to a client the tails are yours, the board have no right to stop you....they just see the red writing on the label and scares the **** out of em.
On another note, I've just been informed recently giving stand by generator supply is notifiable under blah blah, yet I do not normally make any changes to any installation, I don't change the board etc, I just cut the tails...most times it is impossible without cutting seals and withdrawing main fuse. Accordingly that is illegal, is it one law for the board and one for us?
Over the years I've probably done in the region of 50 or so, no board has sued me yet
On another point I've switched to another provider (at home) they came they switched the meter to another (recent) bloodyell what about z\s readings etc they have made alterations...oh we don't bother with that ****, lol. You may laugh but under present legislation they should, in effect it is bull****, sparks know it is, leccy comps know it is, the only people whom don't is the governmentry,
But they can tax you again and create meaningless jobs
You seem to be a man after my own heart Wattsup and a very good point made re ownership of those tails, a textbook example of extraneous legislation making life that little bit more dangerous and inconveient for us all. By preventing access to them via a seal they are appropriating control of it to themselves which in the final analysis is a form of theft as defined in the Theft Act 1968 http://www.lawteacher.net/PDF/TA 1968.pdf
Have to admit, over the years I have developed an excellent and methodical technique to changing live tails if needed. :eek: Shock, horror, call the militia! and won't someone think of the chiiiiildren! Not something I'm proud of so we'll say no more about it eh?
I don't get the issue with cutting seals?:confused: If that is as dangerous as your life has ever got then my advice to you is to live a little. Cmon guys, I cut seals as often as adding new circuits and don't even give it a thought.
I'm with Cirrus on this one
Get 'em cut !!
if they where that bothered about us cutting seals those crimping tools they use to reseal would be available to buy then end of problem.
I would just like to reiterate a former point i have made.
I do not know and have never seen a seal, everytime i change a board the seal has already been removed, honest m'lud;)
PMSL!
Back to cutting seals.
In order to change a cu, or upgrade the tails the supply has to be isolated.
Options
1. Remove tails from cu whilst live. Been there, done that, not much fun and beware of metal clad boards.
2. Contact electricity supplier, ask them to remove fuses whilst work being carried out. If the person you speak to knows what you mean you are doing well. You get a date in three weeks time and between 8am and 1pm or 1pm and 6pm. I'm sure the customer will understand, especially when they do not come back the same day to reinstate the tails (surely not another two to three weeks. oh yes they will bill the customer too.
3. Contact supplier and request an inline isolator to be installed. Have actually had some success with this one. Once you find out who the contract is with locally you can ring them direct and they will try to help. Unfortunately they cannot always fit in with the timescales needed.
4. Cut the seals yourself and replace with some you just happen to have left over from the last time you met up with the suppliers contractor. definately a no no! (Did you know that you can use a standard ratchet crimp to close them up. Meter readers only check they are intact not the number letter code on them, as they are also sub contractors. Well so I've been told :rolleyes:)
What a dilemma, what do we do?
In some areas, where there is not an isolator fitted you can book up to have one fitted after the cu change and they will also replace the seals. When Siemens had the contract in this area this was the normal method and it was done free.
What I find amazing is how many places now are found to have either broken seals or no seals when you go to look at the job!!!!!:rolleyes:
How I see is either wait for few weeks and pay couple hundred pounds or do it yourself and get the job done....Then call Edf or whoever is the provider and report that you just done a job at the address and have found the seal been break. They would much appreciate and then reseal it. I been taught by Ex-Edf guy. got away everytime....!!...
The point is just cut the seal, if they dont like, let em take you court, they will not do so, they cannot win, assuming no option if the tails cannot be isolated by any other means. But my main point is trying to explain to a customer, some think on the wrong side of the box, the main point I'm trying to make is their warning note is illegal, it is not illegal to 'tamper' with your own property. They need suing good style, I aim to make all leccy companies provide isolation on their side, not mine. Their illegal notice is now wearing thin. It will of course cost them loads of dosh, but hey they brought it on..
sec have no problem with the seals being cut, as i said they even supply me with new ones!most new installs have isolating meters anyhow
i cut seal to day i phoned scottish power to tell them what i was doing . i told them the tail on the main board were burning so they said this was not safe so cut away :)
aye, was like it when i got here, honest gov! cuttem every time,bout 75% of ones i see already are cut!:)
yeah I believe you Nathan, got your DAB yet? and get your ruddy hair cut!
your certificates are in as well, i will try and get them posted out to you tommorrow matey:)
just rung southern electric to enquire ....they said cut away, how liberating..........No red tape with them!!!!!! just call them afterwards and they will come round and reseal
Same for me, thats if I remember to call them afterwards:D
It was the meter fairy honest guvnor the seal was off when I got here:rolleyes:
I do always reseal with my own lead crimp & wire purchased from flebay many moons ago.
Reply to Breaking the tails in the Australia area at ElectriciansForums.net
I'm practising EICRs on friendly locations as I'm still in training - technically done my 2391-52 but frankly need loads more practise. I've just...
Was helping a friend out and changing their CU which had a date stamp from 1990. Good quality Merlin-Gerin unit and a nice job originally. They...
If there isn't a 2-pole isolator there already, I usually get the client to arrange to get one fitted before I do a board change, either through...
Hi there, Any advice on this would be greatly appreciated! (Note, this is not a DIY, I'm using a fully qualified electrician, just posting here...
Hi all, Been browsing these forums for a while, always great to learn a new way to skin the same cat. Anyway, cut a long story short, was an...
