Discuss BS numbers for cables in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
K
kevster
ive been asked to provide the bs numbers for all cables i have used on a recent job, my cable supplier is saying that a lot of the cables do not have a bs or en numbers, i thought that you wernt allowed to sell cables without a bs or en number? can anyone shed any light on this
thanks
thanks lenny, should be able to get most info of there, my main concern is that i thought it was against the law to supply anything without a bs/en number?
It is not against the law but if something happened with the item you have used does not have a BS/EN number it is up to you to prove that it is as equal or better than the BS/EN standard.
Reply to BS numbers for cables in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, I am an electrician working for a OEM machinery manufacturer based in Germany, we are the local hub that is now taking over the...
Hi, thanks for reading this. Ive been asked to look at a job where the DNO connection (single phase 80A TT) is a long run to the final circuits...
Hello Everyone, I have a technical question that I hope someone can help clarify. We're currently facing an odd issue with a machine equipped...
Hi There Just a quick one, I'm wondering what's everyone's thoughts on this are. A subby has clipped a cable to a plaster board ceiling using 3m...
When now registering to extend the standard 2 year to 5 year warranty.... They are asking for your "licence number" with NICEIC NAPIT etc or you...
