Discuss building control and certs in the The Welcome Forum area at ElectriciansForums.net
derek
can anyone tell me if building control will accept major works certs, if not in a niceic or similar body, many thanks derek
Presume you mean generic EIC's and Minor Works certs?
its not a case of 'will they', it is a case of 'they have to' in accordance with the Part P rules.
Although they might need reminding of that!
Bare in mind that they are not electricians, and most have never seen BS7671
I have heard of LABC's saying 'what is this?' when presented with a generic EIC. Because its not got NICEIC on the top, company logo etc they get confused
Just gently remind them that its a valid BS7671 cert which the Apprived Document to Part P of the Buildings Regs requires;)
Reply to building control and certs in the The Welcome Forum area at ElectriciansForums.net
Evening all, Just a quick question, I am an electrical maintenance engineer and have 18th edition, inspection and testing and so on, so I get...
Hi as per title I'm building a sublimation heat press. i have a 1000mm x 250mm x 8mm sheet of cast aluminium. i will be using a thermostatically...
As per Part P of Building Regs, once electrical work is performed by a registered competent person, the installation certificate needs to be given...
A long time lurker this is my first post. By way of introduction I have an interest in automation and smart homes - principally Loxone and Shelly...
Hello, I'm interested in working PLC/ industrial controls weekend call-out work for any companies who need it. I'm based in the south of...
