Discuss Bulb staying on in the Lighting Forum area at ElectriciansForums.net
Zaidee
I have a 6 bulb ceiling light. Just recently when i switch it off at the wall only 5 bulbs go out. Is this more likely to be a faulty light fitting or switch?
Have you changed the lamps from filament lamps to led recently?
My next guess is that you have a smart switch, or a touch dimmer?
[automerge]1586761785[/automerge]
Try changing any of the lamps from led to one of the working original filament lamps, I expect the problem will go away
I do have a touch dimmer switch??
I will try that. Thankyou
If you change the switch to a normal light switch, the problem will likely go away even when using all LED lamps.
I suspect the reason this is happening is because the touch dimmer passes a small amount of power through the light to power it’s internal electronics (even when “off”) With a filament lamp, this small amount of power is not enough to warm the filament so the light appears to be off. LED lamps give out light when a small amount of power is passed through them.
That makes complete sense. Thankyou very much for all your advice
Reply to Bulb staying on in the Lighting Forum area at ElectriciansForums.net
Hi all, Great forum with lots of advice read and greatly received over the years! I have a question here that I am hopeful somebody here can...
My kitchen has track lighting. It consists of three halogen light bulbs. I've had the fixture for more than 25 years with no issues. Last night...
Evening all, I've had a few discussions recently that have made me realise that I know nothing about lighting. Does anyone have any recommended...
Hi we are replacing light fittings in our home. Im confident with the fitting aspect, but have run into doubt in making the right choice of...
Good Morning, I've used this forum for advice many times but this is my first time posting so I hope that this community can help! We're...
