Discuss Busbar chamber cable sizes in the Commercial Electrical Advice area at ElectriciansForums.net
Shorne
I’ve been asked to install a dedicated 32amp 3 phase supply for a passenger lift and need to tap off a 200 amp rated busbar chamber. The incoming supply to busbar is 200amp with 120mm SWA. Can I tap off this busbar with 10mm tails to a new 32amp switch fused isolator mounted to the side of the busbar chamber to supply the lift or do the tails have to be rated the same size as the 200amp incoming supply.
Reply to Busbar chamber cable sizes in the Commercial Electrical Advice area at ElectriciansForums.net
Incoming supply on our job comes into the building and then the tails from which go into a switched isolator with 200A fuses fitted. No idea...
Hi everyone, A diversity question concerning 2 consumer units fed from 100amp DNO supply Background, So I have an 18th Ed compliant consumer...
Hello I have two new appliances Electric oven rated at 3.95 KW Induction hob rated at 7.2 KW total of 11.15 KW Currently it is on its own...
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
So far I have never had to deal with a new supply but a possible site we are looking at will need some major changes and so I wondered if folks...
