Discuss buzzin in the Canada area at ElectriciansForums.net
B
bahco
right lads need your help please
ive fitted some lv downlights and a lv fitting in my lounge, took the pendant off into a jb then to the 4 spots and the lv fitting, power on all working fine
then walks past my consumer unit and i can hear a buzzin hummin sound, so i take the lid of listen a bit closer went into the room were i fitted the lights turned them off and the buzzin stops.
now the lv light fitting which i replaced the pendant with had a tranny built in but it was non dimmable, so i replaced it with a osram one
you think it could be the transformer? and also ive replaced the 1g switch with a dimmer, its a 400w dimmer easy enough to take the load but that is makin a slight buzzin sound.
the lighting circuit is on a 6a mcb which powers 4 rooms approx 500 watts which i make round about 3a
getting a bit paranoid now so any help would be great thanks matt
check connections are tight
if it continues to buzz it may be worth while to replace it ,if it has tripped previously through short or overload it could be worn
alternativly take it out ,bang it on the desk a few times put it back see if it that cures it!!!!!
thanks for the replys lads
the mcb was tight, took it out hit it didnt work changed the dam thing jobs a good un :)
cheers
Reply to buzzin in the Canada area at ElectriciansForums.net
Does anyone have any experience of installing Enkin PDM250 Multi-way dimmer modules? We have 4 dimmers at different ends of the kitchen / dining...
Hi all, DIY'er here looking for a bit of advice so please go easy on me. In my dining room there is an existing single pendant and i would like...
Hi everyone, We have bought 2 new low-hanging light fittings from Ikea to go side by side above dining room table to replace the single pendant...
our dimmer switch stopped working after 7 years so went to replace it at the weekend. When I opened it up, the black wire was in the common slot...
I really need help with this puzzler. First - I am moderately 'skilled' in day-to-day basic wiring. My puzzle: I am trying to replace a...
