Discuss C1 + Accessories Connection, what is it for when connecting to a head unit. ignition? in the Auto Electrician Forum area at ElectriciansForums.net
Usually >3 2 1 ignition :). Seriously, we need a bit more info than that . If it is not in the book we will not know either.
Not ignition. It's usually energised at the position before run, for non-essentials that can be used with the key in but engine off. They are often switched off during starting to save load.
A1: -
A2: -
A3: -
A4: (+) Accessories
A5: -
A6: (+ve) sidelamps
A7: (+ve) permanent
A8: Earth
So does my Citreon not provide an ignition or something? At the barebones what connections need to be made? Cheers
Those look like the connections provided for aftermarket entertainment equipment: Permanent supply for the memory & clock, accessory feed for the receiver & amp, and sidelight circuit for the fascia illumination / dimming. The ignition switch / general power control module will have other outputs, for engine supplies, starter etc. either on itself or remotely via the bus.
Yes, what problem are you having? Is the starter failing to turn the engine at position 3 of the ignition switch?
Reply to C1 + Accessories Connection, what is it for when connecting to a head unit. ignition? in the Auto Electrician Forum area at ElectriciansForums.net
Hi everyone I am new in this forum and this is my first thread. Car model: Toyota echo 2004 sedan. I used a multimeter to test the car radio...
Hi there…I’m hoping that someone may be able to help me identify an electrical part of my ignition. For reference I have a 1964 Toyota FJ40 with a...
Hope you're all well . I've had ring door bell 2nd generation hardwired for 1.5 yrs... it was connected to transformer which is connected to the...
Hi, I have lifetime experience (50+ years) in United States with basic knowledge of split phase 120/240 volts replacing wall switches and...
I have pulled out an old evaporative system I purchased many years ago from storage to have a look at it and see if I can get it running. Was...
