- Reaction score
- 0
This is my first time here so please go easy ?
I am currently designing some circuits for large convenience store and I have a question about the thermal insulation derating factor. A radial circuit will feed two display fridges, total load 10A. The circuit will run from the DB through the roof space on a perferated tray to the back of the shop. It will then be installed inside a 50mm aluminium stud wall with thermal insulation.
My question is, do I de-rate the cable by half as it's running from ceiling to floor level? (in excess of 500mm)
Or
Calculate without Ci and choose ref method 102?
Thanking you in anticipation
Or
