Discuss Cable calculation software in the UK Electrical Forum area at ElectriciansForums.net
Hi Guys,
Does anyone know of a half decent cable calc programme? I don't mind paying for one that's good and easy to use but some of the ones ive googled seem very expensive to me.
Are you making lots of complex cable calcs? I can't help thinking you should save your money and just refer to the tables in the regs TBH.
Amtech is the by far the best I've used. For information don't go near Hevacomp. Does your insurance/ professional indemnity insurance make reference to any?
Reply to Cable calculation software in the UK Electrical Forum area at ElectriciansForums.net
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
Hi All, I’m after some advice. I’ll cut to the chase but I can give more detail if needed. A 400A sub main supply needs to be ran 100m, a pretty...
Hi, Small flat, currently has a small'ish feed water tank, top of a cupboard, feed through a wall into under stairs cupboard. Hot water tank...
I was asked to go and take a look at a generator set up by a marquee company yesterday to do some testing. It was a brand new JCB 65QS with...
