Discuss Cable cores outside diameters in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
R
Ross Trician
Evening all, hope your all well and keeping busy.
I am trying to find somewhere to give me information on cable core O/D sizes. For example what is the O/D for a 2.5mm core.
I did have a guidence sheet for this but have lost it. I find reallt handy when doing periodics etc to identify the core sizes etc..
any help gratefull appreciated. Ross
Do you mean the guage of conductor AWG/SWGcross sec area etc. RS do a conversion chart FOC I think.
cross sec area 2.63mm = Nominal conductor Diameter 1.83mm (15 SWG & 13 AWG)
Hello Mike,,
what I want is lets say you have a 2.5mm cable, I want to know what the outer sheat/insulation measures, i.e 3.2mm.
You can use a set of verniers to measure and give a guide to core size.
Might be just me but sometimes strugle to tell the core size if it aint marked on the cable...
am I right in sayin that the awg measurment is the measurment of the core size, i.e 18awg is 1.0mm core size.
thanks
CSA Overall Dimensions
1mm² 7.8mm x 4.25mm
1.5mm² 8.2mm x 5mm
2.5mm² 10.3mm x 6mm
4mm² 11.9mm x 6.25mm
6mm² 13.5mm x 7mm
10mm² 17.1mm x 10mm
16mm² 19.4mm x 10mm
Reply to Cable cores outside diameters in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
