Discuss Cable for Belling FS50EDOFC in the DIY Electrical Advice area at ElectriciansForums.net
Hi,
I am waiting delivery of the above cooker to replace an old model
I will only be using at max the following:-
1 145mm radiant 1200W
1 180mm radiant 1700W
Grill Heating Element 1400W
Will 4.0 mm Twin & Earth flat cable brokay to use? The original cable is a bit aged. As I'm getting a new cooker I might as well replace the cable. I will not be using all the top rings, grill/top oven and main oven at the same time.
Thanks,
Gerald
How long is the length of the 4mm circuit?
Also does it run through any insulation or conduit?
Thanks for the reply,
About 5 foot, out in the open straight from the cooker wall plate, 2 foot from the floor to rear of cooker, so that we can move cooker for cleaning. we have got a pair of Apliance wheels movers.
Ahh right,
I thought you meant from the cooker to the consumer unit..
Twin and eart isn’t really suitable for that, especially if you are going to be moving the cooker now and then.
2.5mm flexible cable will do the job
no ,it will not do .
I seem to be getting conflicting advice.
I've downloaded the manual for the cooker and it states
Rated p0wer on nameplate >9500W at 240V
Diameter of supply cable 3 X 4.0 mm sq
I'll try Belling in the morning
4mm sq flex will be best but because the oven wouldn’t be pulling the full amount of power it could be downrated in theory..
Go for 4mm flexible cable not t+e
Reply to Cable for Belling FS50EDOFC in the DIY Electrical Advice area at ElectriciansForums.net
(Trying again, as picture didn't post first time) Hi, I'd be very grateful if anyone could help me here. Below, I've pasted a sketch showing how...
Hi, I bought my Zanussi ZCV663MWC cooker ten years ago, I replaced the top element four months ago and its been fine until now. When I turn the...
Hi, we are replacing our old hob and cooker and I need a bit of help, to make sure all is safe. This is the oven and hob specs: AEG IKB64401FB...
Hi All, My 1 and half Smeg cooker recently tripped when using the main fan oven. It was during quite a long period of cooking a roast. We reset...
Hello, I have bought a Bell 801 entryphone from Amazon UK and replacing my old one(which wasn't Bell 801). My old phone wiring diagram was...
