Discuss cable for Ex socket in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
any one can share what cable should i be using to connect
a ceag 511 Ex socket to DB?
cheers,
JY
Have done a good bit of EX stuff in sewers for the water board.
You can use normal SWA, but you need EX glands. Get decent ones by Hawke or similar. They are not cheap though, one gland can be £20.00.
If you need reducers, they need to be EX as well.
You only need the EX stuff at the socket end, as the DB wont be in the zone. (I hope)
You could always do it in pyro !
Reply to cable for Ex socket in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, I'm about to reroute cables and sockets/switches from the ceiling down to the socket height after insulating a wall. I understand this will...
Client currently has a DB in his outhouse. It feeds a pool pump and an air source heat pump. It is currently being supplied using a 4mm T&E cable...
Hi All, As a householder I'm keen to add a double socket further along a wall to extend access in a different corner of the room. I'm connecting...
Hi. I'm in the process of getting my qualifications and am taking on some small jobs for family to try and get some experience in. Today I was...
