Discuss Cable for heat pump control in the Solar Thermal Advice Forum area at ElectriciansForums.net
Reply to Cable for heat pump control in the Solar Thermal Advice Forum area at ElectriciansForums.net
Two call outs to new build burnt out heat pumps in a week.
My customer wants to be able to switch his heat pump (3.5kW) for his swimming pool on and off remotely, he also wants to be able to set times for...
Client currently has a DB in his outhouse. It feeds a pool pump and an air source heat pump. It is currently being supplied using a 4mm T&E cable...
I came across this controller that is used to heat a tank located in the loft of a house. The controller seems to be faulty as all 3 temperature...
1 - Major supply fault, details unknown. By time I get there DNO already put in genny and are digging up road. 2 - Reason for call, heating not...
