Discuss Cable TV Setup in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
M
mdsparky
Hi Guys
Living in rural Lincolnshire i've not come across Cable TV before, and i'm looking for the full gen on it. So what cable do i need? is it distributed centrally? is it internet and TV?
I'm a full scope NICEIC registered contractor and I've got a rewire to do in a town with CATV and the customer has asked about setting it up.
Any advice gratefully accepted
Cable tv and broadband come down the same coax with a phone cable alongside.the supplier will connect to a tris 120 box inside the property and everything goes from that,cable is RG6.I'm an ex virgin tech so any more info just ask.
Thanks for that, so if i want to distribute cable tv to many rooms will it be best to go through some sort of booster or splitter?
Reply to Cable TV Setup in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
My garage has had only one electrical outlet, I've decided to add 2 more with each feeding off the original outlet. But upon looking at the...
Hello there, I’m in the process of mapping out a relatively standard S-plan system for my parents central heating and hot water system. Not sure...
A bit of a mini essay but these questions have been building up in my mind over the last weeks and months as I've been studying and volunteering...
I’d like your opinions on a scenario I’ve come across. A certificate was produced which contained errors and while there were still faults on the...
