- Reaction score
- 726
I’m an Industrial electrician and as such have limited knowledge of domestic installations (we all still use the same regs though). I’m wanting to know what people do about the increased insulation in lofts.
For example my shower is a nominal 9.5kW with a 10mm T&E cable If I was to install the recommended 250mm of insulation the cable would no longer be the right size As even though the cable would be lifted out of the insulation, 250mm goes through to the switch, back out and then to the shower so as much as 750mm would be in the insulation (clipped to the beams).
What do you guys do about this ? I was thinking of putting some sort of wooden boxing to keep the insulation about 100mm away from the cable.
Thanks for any advise.
