Discuss Cables run in Wolf Easi joist system in the UK Electrical Forum area at ElectriciansForums.net
Hi Guys Im wiring a domestic dwelling that has the Wolf Easi joist fitted. The central web is great is running services, but how do you fix cables running with and at the normal to the joists? My first thought was mini trunking say 100 by 100, then we should to do grouping calcs. Why trunking well T&E is not self supporting as you all know. Drapping not a good idea, as there is a base layer of 100 Rockwool there to deaden sound from bellow. We could use cable ties, but that brings us back to grouping and they are plastic. Thanks in advance.
Reply to Cables run in Wolf Easi joist system in the UK Electrical Forum area at ElectriciansForums.net
Hi, folks.' I have a carrier 38MGRQ48E '5 zone' mini split system with 4 'heads'/evaporators installed, and one 'channel' still open. Had it...
Hey folks, I had a couple of questions regarding running electrical cables in an attached garage. Any help is appreciated. #1. I am installing a...
5K
Hopefully someone wiser than me can help explain some odd measurements I’ve taken at my own home. This is a long read, I’ve tried to give as much...
4K
Hello, Whilst doing some building works I have access to the inside of the stud wall to which the consumer unit is fitted, so full and easy...
4K
10mm 2+e must run in a 30mm wide gap under floor between wall and joist. Must also be >50mm from surface or enclosed in earthed metal or...
