Discuss cables running along side ch pipes in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
P
paddyscouse
looking for a bit of advice
i have turned up to compleate the second fix on a rewire and noticed that the previous spark has run all his cables up along side ch pipes, about 8ft run, will thease be ok if i separate cables in to a lenth of trunking with no lid to prevent touching plus put some insulation around the pipes, all the cables will haft to be bunched together in trunking due to the space , realy want to try avoid derating the cables due to cost thease people have already paid out to mutch
How close are the cables? Trunking will not stop a lot of heat and it would be best to move the cables away from the pipes if possible as those things get hot especially when boarded over.
I first fixed before a plonker plumber came along, not only used my run,but managed to also tangle his pipes through my cables
With everything in and plastered,its probably easier to move the pipes,like what my plumber had to do
There is non heat conducting material around but it seems like a slap dash solution
Are these cables through holes or slotted ?
- - - Updated - - -
they are running from floor to cieling slotted in between pipes and wall
Ah,sorry,for some reason I just assumed you were talking underfloor
I just typed the following and re read the thread before posting and noticed you had already made the suggestion :)
Is it possible to drill them through the wall at cieling hight and drop them the other side of the wall
if the pipes were fitted after the cables. then get the plumber back to move them. if not, move the cables.
Reminds me of a job some years ago where the 'Heating Engineer' installed some new Boilers and associated wiring in a number of properties. The cables were all twisted round his pipes, answer being the house burnt down. We had to go around and rewire all the properties he had been in ( the wiring was unbelievable ).
My thoughts are, don't let cables come into contact with hot pipework, the two don't mix.
Regards.
Are you planning to issue an EIC on this install, considering you haven't carried out first fix, and possibly don't know what other nuggets of expertise the previous spark left behind?
Reply to cables running along side ch pipes in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi I've got an new outbuilding that needs power run out to it, the building is very close to the house and the original plan was to run an...
I have a customer with a farm who has a barn containing a large 3 phase generator which powers various equiptment at that location. A single...
Before I pay an electrician to come check my work, I thought it worth a post here. I don't want to pay the cost of a small car for a whole-house...
Hello. Just a lowly homeowner here who is beginning to panic after a major house renovation regarding relocation of the main supply cable to the...
  • Locked
5K
