Discuss Cabling where practicality goes a miss in the UK Electrical Forum area at ElectriciansForums.net
Reading about not using pvc t&e externally,what a load of rubbish,just take a look around it’s everywhere.
Not sure if you are being serious, but anytime I see T/E installed externally, I always prepare myself for more bodges inside the property.
I frequently see people on their mobile phones when driving, but it doesn't make me think that lots of people are doing it so its okay!
Pvc t&e is used for external lighting,power,you often see it clipped around walls,EXTERNALLY,it also used to rewire Internally too,
Can you believe that?
We are talking about pvc 6242y,also use lsoh cable.
Found this in professional electrician, and
Generally, where pvc insulated and sheathed (Twin & Earth) cable is routed externally, it should, where accessible, be protected against impact.
My understanding is: the manufacturer’s of SY cable can’t be asked to get BS approval.
The cable’s used all round the world (including the UK).
Why waste the time, effort and money getting approval, when the increase in sales would be minimal?
At least t&e can be considered and disregarded due to the fact it is an approved cable..
Whereas sy type cables don’t.
Basec have condemned their use.
Just because something is widely used doesn’t make it right.
There has been many incidents involving products that have been widely used that shouldn’t have been.
Not aware that BASEC have condemned the use of SY cables.
Last year they were asking for input on specifications for control cables, specifically CY, SY and YY cables.
I read an article that they had published stating that these type of cables shouldn’t be used..
I got involved in a job where sy cables were being run all over the house as submains to all the db’s..
I objected to their use and as support I sought advice from Basec..
Dr Jeremy Hodge the Chief Executive emailed me and gave me the information to support my objection to their use..
I still have the email from basec if it is of any interest to anybody..
Prysmian technical also give some very good information about these type of cables..
Brilliant and about time too..
Hopefully we will soon be able to specify these cables without any issues..
I’m going to send them another email enquiring about what manufacturers are going to be getting cables specified.
Thanks for the update
But you're the only person who has raised the subject of SY etc in this thread? NYY-J has been suggested which is made to a BS-EN standard so is compliant for installations subject to bs7671.
Reply to Cabling where practicality goes a miss in the UK Electrical Forum area at ElectriciansForums.net
Hi All, Im quoting to install an EV charger (Dont worry - fully registered, but only been 2 weeks so i'm still picking bits up). Consumer unit...
Recently changed a CU for a friend and today when visiting one of the RFC's RCBOs tripped. It was due attention anyway as open ring and no time to...
I had a problem a couple of days ago with my boiler shutting down due to too high temperature difference between the input and output, which...
