Discuss Calibration certificate in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
DanBrown
Hi guys!,
Just baught the Fluke 1653 tester brand new, and was wondering if it needs calibrating or do you normally get a 1year manufacturers calibration with the tester?.
Help would be appreciated!
as above should come with years calibration....mr nic man told me that cos ive got a test box that i dont need to calibrate my main tester for 3 years!! is this right (sorry for the hijack just seemed appropriate!) :)
If you bought it from a wholesaler they should be able to contact Fluke and get an extended calibration certificate. They have to confirm to Fluke that the meter has not been used since it's arrival at the branch.
If they not do this for you ask them to get it calibrated for you, at their expense.
When you buy a new meter you intend to use it for carrying out testing in accordance to the requirements of BS7671. If the instrument is not calibrated then it cannot perform the task for which it is intended. Cause for complaint under Sale of Goods Act. Last resort I know but you are paying a lot of money for your Fluke so you need that calibration certificate.
I dont know about Fluke but i've just bought a brand new Megger Mft 1553 and that came with a one years calibration cert..
Thanks for that advice guys!, i will contact fluke straight away and double check this and see why my certificate isnt present.
Thanks again.
I bought a new fluke 1652 yesterday and it's come with the cert and all results dated last November (as had been on the shelf a while). It says on the front of the cert that the date shown might be a while ago, so there is space for you to write the date the unit went into service on the front of the cert, then it says to have it calibrated 12 months from this date. It specifically says that sitting on a shelf won't affect the calibration, it's only using the unit that can knock it out.
Make sure you fax off the form from the fluke site before the end of the month too for your free stuff Fluke - Test and Measurement Equipment
Reply to Calibration certificate in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi all My Fluke tester failed on one test today while having it's annual calibration, the continuity resistance test current. Test Current -...
Hi! Some help would be appreciated! I've just moved into new house, wanting to check insulation resestance etc as getting some nuisance...
Hi Still fluke 1664fc is a good tester or there is other new model on the market? Any brand and model will be appreciated, not the megger please.
Hi, So I have decided to sell my Megger MFT1721 - See photos below. Originally I bought this for when I was doing my C&G 2391-52 course & then I...
Hi I've got a megger mft 1720 that I was hoping any one can shed any light on When performing continuity tests (even when nulling the leads)...
