Discuss CamLock Box install - 3 Phase in the UK Electrical Forum area at ElectriciansForums.net
rjpra2
I am needing to install a CamLock power box to provide power to some equipment. Located in a commercial office building.
The equipment is a robotic arm that requires 208V, 3 Phase Power, 30 Amps max. It comes with a controller and transformer.
The overall power flow is as follows:
Building > Electrical Panel (120/208V, 3 Phase, 100 amp capacity) > Circuit Breaker (30AMP, what voltage?) > CamLock box (120/208V, with Blk/Red/Blue/White/Green) > Transformer (Inputs 208V and steps up to 480V for robot) > Controller > Robot
Do I have the correct CamLock box for this power flow to work, since Transformer requires 208V? Would the Camlock only be wired for Blk/Red/Blue/Green and exclude the White to provide the 208V?
Thx.
CamLock fittings are kind of overkill for your stated application, is this something the supplier has specified?
Here in Australia I would use a 32A 4/5 pin plug and socket arrangement for such a supply, I'm sure there are equivalent products in the US market.
Have a talk to someone who does industrial electrics in your area, they will know more of the local codes. You also shouldn't exclude the neutral conductor unless you know for sure the robot only needs 3P&E.
Hey,
Thx. Yes so the supplier specifies CamLock.
They are providing me Robot, controller, transformer, and camlock cable. The transformer has CamLock inlets, Blk/Red/Blue/Green on it, so inputs 208V and steps up to 480V for robot.
I need to get camlock box to connect between electrical panel and transformer.
Wondering if the CamLock is there due to the 3Phase requirement of the robot.
Curious if in my power flow it sounds like the specification of Camlock sounds like would work (120/208V 3 phase), and if would only wire Blk/Blue/Red/Green to electrical panel?
Thx
Reply to CamLock Box install - 3 Phase in the UK Electrical Forum area at ElectriciansForums.net
Hey all. I have a Hobart LXe commercial dishwasher that Im trying to run on 3 phase power. The manual specifies 208-240/60/3 with an ampacity of...
Hi Guys, We have a CNC router which uses single phase for the spindle, stepper motors and control box. This is all wired in and working...
I have a single phase stainless steel pasteuriser that has two control boxes attached to it. One box houses the control for the electronics and...
Hello all. I am trying to get 125 amps 3 phase back to a paintball field to power an electric air compressor. I have a 3 phase 120/240v PG and...
I have pulled out an old evaporative system I purchased many years ago from storage to have a look at it and see if I can get it running. Was...
