Discuss Can a 220 circuit power a 110 outlet? in the UK Electrical Forum area at ElectriciansForums.net
My76strat
Is it ok to run a 110 line off a 220 circuit? Specifically, I want to add a 110 outlet near my hot water heater and it would be convenient if I could use one of the hot wires along with the neutral and ground to create the circuit I should also mention that the 110 line will almost always be in use. Thank you
can't see a problem aas long as the cable/s will safely carry the load current and are correctly protected by a fuse or MCB. what is the rating of the heater and what cable size?
There’s one problem, the water heater doesn’t have a neutral
Thank you Megawatt. I realized this fact yesterday as I was taking steps to install the outlet. Of course, I've scrapped the notion and decided to run a dedicated circuit for my 110 needs at that location. I probably should mention that I'd moved my hot water heater outside and was hoping to install the 110 outlet without having to run approximately 60 feet of 12/2 wire.
My friend sometimes electrical work is not easy. Good luck
Reply to Can a 220 circuit power a 110 outlet? in the UK Electrical Forum area at ElectriciansForums.net
I have an existing but unused 50A disconnect on the side of the house. It had been connected to an AC unit that got replaced. It has just 3...
Mobile home outdoor power supply is a pedestal that power to the mobile home plugs in much like an RV. The main power supply into the mobile home...
we just replaced our hot water tank with hot water on demand (natural gas) and still have the old power run for the tank which is 30a 240v. I...
I have three outlets (that I can find) that are showing open neutral. I have 80v across hot and neutral, 120v at hot to ground and 28v neutral to...
