Boholighting
- Reaction score
- 6
- TL;DR
- Can anyone spot why this is not working?
Discuss Can anyone spot what’s wrong? in the DIY Electrical Advice area at ElectriciansForums.net
I am trying to attach the video to show the problem
Thanks for your help. I'll try that. I am new to lamp making so I imagine a multimeter is a must-have.The video attached fine.
First thing, eliminate the obvious…. Is the 3A fuse good? Swap it with another table lamp.
Is the bulb good? Same. Swap with a known good one.
After that, it’s needing testing with a multimeter
We have light! Replaced the fuse. Thank you so much for your help.The video attached fine.
great.We have light! Replaced the fuse. Thank you so much for your help.
Yes, I replaced it with a 3A fuse.great.
As long as it was replaced with a 3A or lower.
Reply to Can anyone spot what’s wrong? in the DIY Electrical Advice area at ElectriciansForums.net
