Discuss Can i add a 2nd light to existing circuit in the Lighting Forum area at ElectriciansForums.net
Hey guys... about to do a bit of minor reno in the kitchen and wanted to add an extra light to a spot that's poorly lit.
Old house, old wiring, 9ft ceilings covered in copper so can't really get into what's there except to say there is a ceiling light in the centre and 2 light switches, one at each door.
I want to add a light to the wall a few feet over and up from one of the switches.
Is it as simple as cutting the wire at the one switch and running wire off of it? Basically a Y split for each wire? Or would that mess it up?
more likely to run a cable from the existing light than from a switch.
To make a light work you basically need a live and a neutral. Light switches do not usually have a neutral.
It’s unlikely that you can do what you need from the switch wiring, but post a photo of your switch wiring, and we can confirm.
Welcome to the forum mate.
Does the house CU have a RCD fitted to it?
If you are taking pics of the light switch, and isolating the circuit, then take a pic of the wiring going to the existing light. As @telectrix has mentioned, taking the supply from this may be the best way.
If you don't know the answer to the above RCD question then post a pic of your house CU as well.
Like I said, taking that part of the wall apart and can take a photo of it.
Light itself... can't really... need someone with a ladder tall enough to reach that high plus afraid to touch it in case it stops working. 90% of the wiring in here is still knob/tube... 110yr old farmhouse.
No clue what RCD or CU is. Responsible Cannabis Use? Credit Union? :D
Reply to Can i add a 2nd light to existing circuit in the Lighting Forum area at ElectriciansForums.net
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
hello all. I am trying to add led strip lights to my boat trailer. I have marine grade submersible lights. I will have them running parallel to...
Hi all, DIY'er here looking for a bit of advice so please go easy on me. In my dining room there is an existing single pendant and i would like...
Hi everyone. I live in an older home that still has a few circuits with aluminum wiring. One of these is a lights-only circuit that contains 6...
