Discuss Can I add a motion sensor in the Lighting Forum area at ElectriciansForums.net
Mrs.sw21
Hi
In my hallway I have several led floor lights that are plugged into a wall socket
Can I add a motion sensor so that they switch on when I walk into the hallway
Thanks for any help
Hi
Thanks for any help
Welcome to the forum mate.
So currently you switch the floor lights on by switching on the socket?
You could add a motion sensor to switch these light on but you would have to put it between the socket and the lights.
I'd also get a sensor that has a Dusk function, so that the lights don't come on during the day, when it's light.
Thanks for the reply
Can you recommend a sensor
Doesn't really matter about dusk, as it's quite a dark hallway
[automerge]1570372875[/automerge]
Thanks for the reply Can you recommend a sensor Doesn't really matter about dusk, as it's quite a dark hallway
Hows your current lights installed and operated?
Is it as I have mentioned above?
I'm presuming that the cable from the socket to the floor lights will most probably stay at skirting board height.
It would be better to know the layout of the lights and where the sensor is going to pick a sensor.
Any chance of uploading some pics.
Yes skirting board height. Can't really upload pics as at my sons house. Was just trying to help him out
Don't worry about it. But thanks anyway
Get your son to send over some pics to you and you can then upload them.
Ze, Germans have thought of it.
Just need to find one with uk fittings
edit, or how about this?
Reply to Can I add a motion sensor in the Lighting Forum area at ElectriciansForums.net
Hi, Some advice would be appreciated… I have 4 downlights in the bathroom and want to add a motion sensor to turn on just one if everything is...
Can I use multiple GU10 led lamps with their own PIR sensors in the same room? I have a row of existing lamps 600mm apart in a straight line & I...
Hi, I have two 3-way toggle switches by the opposite sides in my garage. Is it possible to replace both of them with motion sensors? Thank you. .grig
On either side of my front door is a motion sensor wall light - it looks like both lights operate from one light switch inside the house. The...
hello all. I am trying to add led strip lights to my boat trailer. I have marine grade submersible lights. I will have them running parallel to...
