Discuss Can I connect the neutral and ground when wiring a 3 wire cable to a 4 wire outlet? in the UK Electrical Forum area at ElectriciansForums.net
I recently purchased a steam sterilizer with a PID controller and I'm trying to figure out how to power it safely. The sterilizer requires 240v but the PID (if I understand it correctly) uses the return 120v on the neutral wire. My problem is that I have an old house and the neutral and ground connect to the same bar.
My initial thought was to buy a breaker, 10/3 w/ground Romex, and an L14-30r outlet. But then I thought I could save a bunch of money if I just repurposed an extension cord I made for my kiln. The cord connects to my dryer outlet (10-30r) but only contains 3 shielded wires -- no ground. I would replace the kiln end (6-30r) with an L14-30r.
Since the neutral and ground connect at the breaker anyway, could I just install a jumper on the L14-30r between the neutral and ground terminals? Would this cause any problems for my device?
Reply to Can I connect the neutral and ground when wiring a 3 wire cable to a 4 wire outlet? in the UK Electrical Forum area at ElectriciansForums.net
I have breaker box at least 40 yrs old, both conduit and romex enter box, only one neutral bar that all white wires and bare ground wires attach...
I have an existing but unused 50A disconnect on the side of the house. It had been connected to an AC unit that got replaced. It has just 3...
Hello, I live in Costa Rica, which adopted the US electrical code. On a regular basis, during thunderstorms, I have parks coming out of the...
In the UK, It is said that the neutral wire is connected to ground/earth wire along the way back to the substation. Ive inherited a setup where...
Replaced our old 240v hot tub with a new one, which also uses 240v for motors, heater, etc, and 120v for low amp LEDs and touch screen control...
