Discuss Can I hardwire, or must I use Panasonic VL-SWD275 power supply? in the Electrical Appliances Forum area at ElectriciansForums.net
Purchased a Panasonic VL-SWD275 video intercom from Australia to replace my 2-wire intercom in the US. The Panasonic VL-SWD275 requires 220v and 24v DC at 6amps. I purchased and installed a Zerone AC 100-240V to DC 24V 6-9A Switching Electricity Supply Module 150W step-ups transformer into the outlet thinking I could wire the main monitor directly to the board according to the research I'd done.
The Panasonic VL-SWD275 kit includes a 220/240v power supply that has a non-polarized AC input, and a 24v DC -/+ terminal output. Th
e main monitor includes 2 power input terminal ports, but says the wires must be non-polarized!!!
1) What does that mean? Does that mean I can use the -+ 24v DC wires from the transformer?
2) Can I power the VL-SWD275 with the red and black +/- 24v DC output wires from the Zerone step-up transformer and omit the power supply in the kit????
Reply to Can I hardwire, or must I use Panasonic VL-SWD275 power supply? in the Electrical Appliances Forum area at ElectriciansForums.net
Cathodic Protection Station with Switching Power Supply for Buried Metal Structures Benefits of the Switchmode Cathodic Protection Rectifier...
Hello, I am fitting a Telecom 8 Compact burglar alarm system to a boat. The boat has both nominal 12v DC supply (ie up to 14.2 v when engine...
Hope this is the correct forum for this. I have a chandelier that holds 18 bulbs, it's not in use since ages ago and I was planning to restore...
How do I limit or feed inrush current for higher constant current use? If I could find solution, then the chosen battery cell type can have much...
Hello, I am the artist, (I'm not an electronist or electrician). I have a weird problem that I never encountered. I have a small power supply led...
4K
