Discuss Can I replace a 15w with a 25w in oven in the Electrical Appliances Forum area at ElectriciansForums.net
Can't imagine the extra heat would be an issue...
at 230V its still only 0.11 of an amp or so. I'm pretty sure the wire used will be well over that capacity.
A 15W bulb is shorter in length (47mm) than a 25W bulb (55mm). The glass protector may not fit over the 25W bulb. If it does it may not leave a small air gap between the glass protector and the bulb, it could also break the bulb when the protector glass cover is tightened.
If there is extra space to accommodate a 25W bulb then it should be okay.
Helpful info.
About 5 years too late for the OP, but someone else might find it useful.
Reply to Can I replace a 15w with a 25w in oven in the Electrical Appliances Forum area at ElectriciansForums.net
I purchased a new-build apartment 10 years ago, which came with a fitted oven and microwave. Both appliances are described by the manufacturer...
Hi All, Thank you for your previous advice - it resulted in us replacing our precious Smeg range with a Hotpoint; however we now have a new issue...
Hi All, Seeking some thoughts on my own Omega free standing 900mm oven. Over the past year the oven has been tripping the supplying RCBO unit. I...
I have just replaced my old double oven which was about 10 years old with a new model as whenever I used the top oven it tripped the electrics...
Hi all, There's 2 single fan ovens in the house my mother recently moved into. Posh elecronic AEG units. It's been sat empty for a year, so the...
