Hi, I'm a DIY'er but not a DIY electrician. I have a 3.5kW oven (15A min. 20A max. fuse) and want to connect a separate 7.4kW hob on the same 40A kitchen circuit. Looking at other posts in this forum it looks like it’s ok with a dual outlet, but do you need the cable dia. To check this first, or is it 6mm standard?
Also (Q.2) There’s currently one 13A socket on this loop. Can I keep this on this loop or is it mandatory that it goes on a separate loop (I’d like to keep it as it is if possible)?
Advice on either question gratefully received. Hoping to understand what I’m asking for before getting it connected.
