Hello,
I am an American living in Germany. I have some US appliances (120v) that I want to use, so I bought a 5000 Watt step down transformer.
Unfortunately, plugging in the transformer usually trips the breaker. More than 1/2 of the time, but less than 3/4. When the breaker does not trip, nothing I use with the transformer causes the breaker to trip later. My searching tells me this is a symptom of an inrush current problem.
The circuit I am using it on was originally on a 16amp breaker with a B curve. With the B curve breaker, the transformer tripped the breaker 100% of the time. Online advice recommended changing a B curve breaker for a C curve breaker to handle the inrush and indicated that this was safe. So, I replaced the 16 amp B curve breaker with a 16 amp C curve breaker.
Does it sound like this is an inrush current issue, and that installing a D curve breaker might resolve it? Should I be able to safely install a D curve breaker (sticking with 16 amps, of course) on the circuit that originally had a B curve breaker?
If it's not that black and white, what other info would I need to know, in order to determine if it is safe to install a D curve breaker?
Many thanks!
Many thanks!
- TL;DR
- Transformer is tripping a breaker. The internet says to install a D curve breaker. I know how to install breakers, I don't know how to tell if this is OK to do.
