Discuss Can I use CAME dir 10 photocells with generic pair and 909 control panel? in the UK Electrical Forum area at ElectriciansForums.net
I’m installing a driveway gate and need two sets of photocells in series to stop gates when car is in the way of either pair. The set that came with the kit are straight forward, both units have a + and -. The receiver has the contact that’s closed when there is nothing in the way. Another pair the same would be easy to wire in series. But the 2nd pair are CAME dir10. The wiring diagram is different, it has a link labelled tx which joins the transmitter to receiver and doesn’t go to the board. The wiring diagram is different, are they compatible with the kit? The first pair only has 4 terminals on the receiver and no tx link as shown.E5765699-48DF-4C89-8AF5-69369766638D.jpeg
Reply to Can I use CAME dir 10 photocells with generic pair and 909 control panel? in the UK Electrical Forum area at ElectriciansForums.net
Ferrets are known for being small, resourceful, and incredibly clever. They can solve many problems by fitting into tight spaces and doing jobs us...
We have this Swiss-made Dixi horizontal borer from 1957, very nice machine still with its original DC variable voltage drive. In those days there...
Hi there, I just purchased a sailboat and its electrical system was put together in questionable ways.. It came with an 815W array of mismatched...
My view on life, in any field, is not to produce more but to consume less. Everybody told me this is a very eccentric weird mentality. Perhaps...
Hello All using the following units KFX 100 Break Glass Reset Button 3FC F20 EU 2 units (both opening 2 vents) 3FC F10 EU 1 unit (opening 1...
6K
