Discuss Can I use the existing 1/1/4” pvc pipe to fit 200amps rated wires, in the UK Electrical Forum area at ElectriciansForums.net
I am doing a 100 to 200amps (underground) service upgrade.
Can I use the existing 11/4” pvc pipe to run the 200amps rated wires?
What is the smallest size of wire I can use for the 200amps?
8DF13F85-7C54-413B-BC1C-236DA7F08775.jpegIs (2) #2/0awg copper & (1) #6awg neutral copper ok?
This thread might be better placed in the Canadian subforum as the practice here in the UK is different.
View attachment 52927Is (2) #2/0awg copper & (1) #6awg neutral copper ok?
200 amp three 2/0 copper one # 6 ground or 4/0 aluminum both choices require a 2inch conduit sorry
Reply to Can I use the existing 1/1/4” pvc pipe to fit 200amps rated wires, in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm a DIY'er looking to build a 6x8 shed in my backyard in Colorado. I'm installing a gravel pad first, with 4 concrete Sonotube...
I would like my plan checked by a professional. This project is a semi-open pavilion with a load center approximately 100 feet away. I am rating...
At my new lake house, I'm planning to rebuild an unattached shed and make it a Shed/Bunkhouse combo. The current wiring to the existing shed...
Before I pay an electrician to come check my work, I thought it worth a post here. I don't want to pay the cost of a small car for a whole-house...
