Discuss Can my existing receptacle work for this? in the UK Electrical Forum area at ElectriciansForums.net
I have a new homebrew machine, but it comes with European cables and plugs. It's a 230v two prong to a C13 connection.
I have a EV charger in my garage, it's a nema 14-50 on a 50amp breaker.
My thought was to get a c13 to 6-20R and then plug that into a 6-20 to 14-50 adapter and plug it into my existing 14-50 plug.
Looking for some advice if this is possible, or should I just cut the european plug and wire up a new 6-20 outlet. Want to avoid doing anymore breaker work if possible.
If it came from the UK listed as 240vac and the wires also, their 240vac consists to 1 live 1 neutral where ours is 2 wires and a neutral. Unless you can find an adapter do not start trying to wire a different cord to it.
All is not lost! You can also rewire internally. I have had to do these "field modifications" often with machineries. You may need to replace the cord as well.
Refer to the product manual & above all BE SAFE. If you're not sure hire a professional.
Good luck.
Reply to Can my existing receptacle work for this? in the UK Electrical Forum area at ElectriciansForums.net
Mobile home outdoor power supply is a pedestal that power to the mobile home plugs in much like an RV. The main power supply into the mobile home...
I have an existing but unused 50A disconnect on the side of the house. It had been connected to an AC unit that got replaced. It has just 3...
I installed a new 50 amp circuit to charge my EV. Some specifics on the circuit - 50 amp breaker, 6-2 ga copper wire (UFB because in the future I...
Hi, Sorry, lengthy post. Really only need to read the next sentence to be able to answer my question. The rest is what I have considered and...
Hi, New to the forum. I have two very specific questions, for the setup below. Setup details: Currently I have a setup with an outlet used for...
