Discuss can some one anser this please in the Canada area at ElectriciansForums.net
M
mike
hi can some one please anser this for me. i have used a over haed catinary to support a 1mm t&e i have ran a sperate 6mm earth and connected it to the catenary, it is metal so it must be earthed, what size earth should i have used to earth the catenary wire. thanks
hmm, not sure but although 6mm should be adequate, I would have probably stuck in 10mm earth same as an earth rod or main bonding just to b safe
if the catenary wire needed earthing then what would it be classed as ,personally i'd just put in same size as gas or water (main equipotential bonding)
Reply to can some one anser this please in the Canada area at ElectriciansForums.net
I have had these lights installed by a contractor whose work is normally very good. He has not connected the earth in each fitting as there is a...
Client currently has a DB in his outhouse. It feeds a pool pump and an air source heat pump. It is currently being supplied using a 4mm T&E cable...
Hi, New to the forum. I have two very specific questions, for the setup below. Setup details: Currently I have a setup with an outlet used for...
