- Reaction score
- 0
I’m a junior electrician, fresh out of college. I did some minor electrical work for a friend buI tried to put up a new chandelier I came across:
The chandelier has one line, one neutral and one earth.
I wired it up putting the neutral in one neutral block. When turned on the bulbs barely lit up.
When i switched the wire to the other neutral block it lit up greatly, however could not be turned off.
When i put both neutrals in one block, the light lit up, but tripped the fuse when I attempted to turn it off.
I know little about old domestic systems. Can someone please advise.
- Two Line wires (RED), going into one connector block
- Two Neutrals (BLACK), separated into different connector blocks
