Discuss Can someone please help with baffling problem with my lights on Audi A6? in the Auto Electrician Forum area at ElectriciansForums.net
PeterM11
Hi there
I wonder if you can help me please?
I have a problem with the drivers side rear lights on my (2007) Audi A6. (includes taillight, reverse light, brake light and indicator.)
All other lights are working perfectly.
I am baffled because – when I’m stationary – before setting off – all of the lights usually work. Then, when I turn on the ignition and drive away, the lights fail and my warnings come on.
So, the bulbs seem ok – but I don’t know what’s causing the problem! D’you have any idea what’s likely to cause this? All the garages are fully booked until January, and I really need my car over the Christmas holiday season.
Thanks so much for any hints or suggestions you can share,
Peter
Look for corroded contacts or loose plugs.
could even be a ground wire problem
Hi there
Peter
Try Googling, seems to be a common problem, need to clean ground connection eg:
Take special note of post #9 in the thread linked above.
Agreed. Actually interesting throughout, particularly the link to a more 'permanent' fix!
Extreme, but permanent fix, would be to hardwire the brown wire to the cluster, bypassing the plug and socket.
Had a Corsa with a well known instrument cluster plug fault that kept bouncing back. Finally took the bull by the horns, cut off both the plug and socket, and spliced in a couple of feet of new wire.
Reply to Can someone please help with baffling problem with my lights on Audi A6? in the Auto Electrician Forum area at ElectriciansForums.net
Hello all. So I am sure the expertise on this forum will be able to decode this very easily. But it has completely baffled me. I'm in training so...
Hi all as mentioned I fitted two new stedi led indicators to my Suzuki 2018 drz400sm the front ones not stedi were fitted by the previous owner...
I bouught a Nissan Townstar EV and have found what I consider a theft problem All previous vans I have had allowed the driver to enter and exit...
