Discuss Candy fdp232 oven in the Electrical Appliances Forum area at ElectriciansForums.net
Nick80
Hi
My candy fdp232 main oven has suddenly stopped working - the upper oven, main oven light, cooler fan and clock all work, as does the light which indicates the oven hasn't yet reached the required temperature. But the fan and heating elements are not working in the main oven.
Any ideas on what this could be? Is it worth attempting a repair/getting someone out or just replace the built in oven?
Is the clock set properly (ie not flashing) and the programmer set to manual? Otherwise the bottom oven may have been switched off by the programmer.
Otherwise it could be (though unlikely) the knob/temperature control assy - suggest a multimeter to diagnose the problem.
It's definitely not the clock (set properly) or programmer - the light/extractor fan doesn't operate in that case. Everything is working except the heat/fan. I will remove it in the next few days and check with with a mm
Reply to Candy fdp232 oven in the Electrical Appliances Forum area at ElectriciansForums.net
Hi All, Thank you for your previous advice - it resulted in us replacing our precious Smeg range with a Hotpoint; however we now have a new issue...
Hi All, My 1 and half Smeg cooker recently tripped when using the main fan oven. It was during quite a long period of cooking a roast. We reset...
I have an electric oven - now many years old. I have replaced the main circular 2.5kW oven element (ELEHY6708) several times over the years...
My Neff oven is approx 10 years old and has worked normally,until about a few months ago when it has started to trip on RCD when at high...
Hi Our oven stopped working suddenly including the clock. It was on the fan oven setting at about 150 degrees. I checked the fuse board - it had...
