Discuss Can't afford LEDs in the UK Electrical Forum area at ElectriciansForums.net
V
varilite
Heres the solution
Don’t know whether you are old enough to remember Benneton clothing shops, but for a while all their stores had lighting schemes which made a feature of CFL’s in a similar way…..
Reply to Can't afford LEDs in the UK Electrical Forum area at ElectriciansForums.net
Hi, want to installed some LED strips in the ceiling and wanted to know how the recessed LED profile is fixed in place and stop the plasterboard...
Had to remove a led strip from a bathroom today because it’s getting tiled, now the led strip that was there was low voltage but didn’t have...
I'm looking for an LED spotlight that can be mounted on an existing lighting column. The aim is to illuminate a war memorial that is 20m away...
Hello Can keyboard led on when i remove data pin Data Clock will caps on without data and clock
Hi all. Slightly out of the ordinary, but I'm looking to replacing between 60 to 100 standard size E27 bulbs with LED equivalent. The catch is...
