Discuss Can't get out of engineer mode on galaxy 3-144c panel in the Electrical Engineering Chat area at ElectriciansForums.net
J
Jak1708
Hi all
Someone accidentally hit the panic alarm and so my alarm went off, I entered my managers code to stop the sounder. The keypad then said "manager reset required" so I entered manager code and tried to clear message but it wouldn't work at all, so I entered engineer mode and the message went, however now when I try t exit engineer mode the panel "checks for tampers" and says there is a tamper on number 4 however I now there isn't anything connected to number 4 ?! Only circuits 1-3 are used,
Is there anyway around this ? I can still set the alarm and everything else's is as normal but the panel constantly says "engineer mode" and I can't exit it .
Jack
Enter engineering code and press esc key, hopefully you know the code :)
Try 112233 plus enter, is generic code, hope it works!
Hi
Ye know how to get out of engineer mode but when i enter the code and press esc the panel displays "checking for tampers" it then says there is a tamper on 0004 and therefore it can't exit engineer mode until the tamper is fixed however I know for a fact there isn't anything wired into 0004,
There is just
Door contact 0001
Pir 0002
PA 0003
Must be a wiring fault or resistor fault.
Check that the terminals are tight, assuming that you have something connected on cct4.
Jack[/QUOTE]
Hmm, Iam not familiar with this particular panel, but I was wondering if you could just omit that zone, or if the tamper loop link had to be physically present.
Thanks all
I set 0004 as spare but that didn't help it still says there is a tamper on it, I also omitted the circuit again that didn't help, I can only imagine that there is actually something on circuit 4 that is causing the problem I'm so sure that there isn't but it seems the only logical explanation
Reply to Can't get out of engineer mode on galaxy 3-144c panel in the Electrical Engineering Chat area at ElectriciansForums.net
Hi everyone, first post here and in a bit of a pickle... Newly qualified out in the big bad world... I have a job 4 hours from the office so I...
I have a DSC POWER832 alarm with an LCD5501Z kepad and I'm 99% sure it's a PC5010 panel. And since I switched from DSL to Verizon FIOS...
Hi there unsure where to ask so i have joined this forum hoping someone will know. I am currently employed by a large firm as a fire alarm...
Hi all. I have been trying to do some reading up on my options for possibly doing a HNC next year. I had originally looked at doing a HNC in...
4K
I'm having problems with my Optima XM burglar alarm. Yesterday the outside alarm suddenly went off. I removed the battery from the conteol box...
12K
